- 18 May 2010
- London
AMD doesn't have fastsync yet, which is what you asking for.
Ahhh nope. I'm referring to adaptive vsynch in the drivers!
Ahhh nope. I'm referring to adaptive vsynch in the drivers!![]()
Nvidia Adaptive V-Sync will turn on V-Sync when the game's framerate hits the monitor refresh rate
AMD advices to either set the fps limited to 1 fps less than you monitor from the driver settings, or activate Vsync and Freesync. But I have always preferred the driver option.
Everything is capped at 143fps.
Ah... so AMD have an option to cap fps in the driver? So I could set it to 59 and effective have no tearing?
Is this an easy thing to set in the AMD drivers?
Reading this back to my self, it sounds like I need a new monitor!![]()
Not serious at all which most of the time is the state I float in ...Not sure if serious
Trust me without it there would have been at least one person who would have not got it. I mean Doom and a few actually think this way so...![]()
good thing you put sarcasm at the end, everything you said was totally believable up to that point ...
Hahahaha. I think after the /s at the end you liked me even moreYeah I was thinking I use to like this guy at one point then the /s at the end made me like him again![]()
I have mine set to 60 in global. I do not think setting it to 59 will magically help with tearing. Would it reduce it even a little? Doubt it, hence never tried.Super easy, just a few clicks in total.
I use it to cap my FPS at 143 so it never goes over my monitor's 144Hz.
Not sure but AMD have said themselves that using FreeSync + VSync is their recommended combo, and that VSync will only kick in if you're at maximum refresh rate (or higher), so no input lag or anything below that.So AMD neither have adpative vsynch or fast synch driver side?
That would actually be a big deal to me as although the plan might be to upgrade the monitor at some point, it does incur an additional cost.
AMD and their drivers.... do they have things like Adaptive Vsync? What about something similar to fast sync?
For me, a HUGE deal was adaptive vsync with Nvidia cards as I have an older monitor and it tears like crazy.
Saying that I do still actually get tearing even with adaptive vsync.
Supposedly the Instinct MI25 is already a Pro Vega based GPU.
Until recently I ran a 3GB card fine on 1440p and it would still cut it today mostly but that isn't going to last forever and 4GB seems potentially a bit limited going forward if developers do actually start squeezing more out of the VRAM with next generation effects when they are less limited by having to accommodate the memory usage of the API.
While 4gb will become useless in the future it is still good enough for now, mean 1gb & 2gb still get used, hell that 1060 has a 3gb option, it's not so much the amount, it's what you play that requires it, so far the division has been the only game to use nearly a 2gb vram limit in my experience, sometimes there's hardly much difference between high & ultra depending how the game engine is used as games with the same engine are not identical. If your paying stupid money then you'd ideally want no less than 8gb, I'd only buy the 2gb rx 460 because its less than £100.
both parties are making cards with less than 4gb vram still, so I don't know what market both are more focused on or if they trying to balance it.
