Hi,
Looking for a new AIO cooler for your build then we have got this little beauty as an exclusive Overclockers UK product. Compatible with the most up to date sockets including Kabylake and Ryzen. Comes with a OEM H100 cooler, 2 x SP120 RGB fans (Retail Packaged) and an RGB controller. Cooler includes a 5 year warranty.
Just to be clear this is not a newly released cooler this is a idea we are working with them as a good deal to offer you guys.
Corsair H100 RGB Extreme Performance Liquid Cooler **OcUK Exclusive** @ £99.95 inc VAT
Socket Compatibility: 775 / 1150 / 1155 / 1156 / 1151 / 1366 / 2011/ AM2 / AM2+ / AM3/ FM1 / FM2 / Ryzen
Liquid cooling works better than air cooling, and the self-contained design of the H100 gets you up and running quickly so you can spend more time enjoying the performance of your overclocked processor and less time assembling, filling, and maintaining your cooling system.
The Corsair SP120 RGB LED high performance PC case fans combine excellent air delivery with hub mounted RGB LEDs and translucent, frosted fan blades for brilliant lighting. By utilizing ultra-thin fan blades the SP120 RGB LED fans are custom designed to deliver air directly to high-temperature components with less noise and turbulence than ordinary fans. Each fan offers bold lighting with vivid lighting effects.
Features:
- Large 240mm radiator: more cooling capacity
- Improved coldplate and pump design: better efficiency gives you lower temperatures with less noise
- Advanced SP120 RGB PWM fan design: better high-static pressure air delivery and customizable speed
Cooler Specification:
- Radiator dimensions: 276mm x 125mm x 30mm
Fan Specification
- Fan Dimensions: 120 x 120 x 25
- Rated Voltage: 12v
- Speed: 1400 +/- 10%
- Airflow: 52 cfm
- Static Pressure: 1.45 mm-H2O
- Sound Level: 26 dBa
- Connection Cable: 3 pin
- PWM Control: No
- Bearing Type: Hydraulic
- Cable Length: 600mm
Box Contents:
- Corsair Hydro Series H100 OEM
- Mounting kit for all modern CPU sockets
- Intel, AMD, Ryzen Compatible
- Two SP120 RGB 120mm fans
- RGB Controller
- Fan and radiator mounting screws
- Thermal compound (pre-applied)
Was £99.95 inc VAT.
Now £89.99 inc VAT.
ORDER NOW
Features:
Fan Specification
- Airflow: 52 cfm
- PWM Control: No
Box Contents:
- RGB Controller
Was £99.95 inc VAT.
Now £89.99 inc VAT.
ORDER NOW
