Cat i think the problem is your making mountains out of molehills and conjuring up issues that are not there...
The facts are as follows
1) Intel does not scale as well as AMD does with faster Ram
2) AMD Ryzen scales incredibly well with ram, to the point its a necessity to user the fastest ram possible
3) AMD are still working on providing the best ram support, in the meantime your mileage may vary in ram compatibility
4) Anyone can cherry pick reviews to show any point they are trying to make, we all know it, you know this to be true
5) Why cant we all just get along!![]()
That's an i5-6600, not an i7-7700K. I could be wrong but that could make a big difference. Also, I don't like the fact that these review videos never actually show you the hardware setup used, even in the description. I assume it's 1080p with a Titan X OC or something crazy? At least a 980 Ti is more realistic.
Look at the scaling from 2133MHZ to 3200MHZ. Remember,DF uses custom sequences.
I think that's fairly obvious - when doing internal testing of performance improvements it's likely that the testing team uses their own in-game benchmark, so in theory that will always be the best case scenario. It probably shows that the in-game benchmark is a poor representation of game performance more than anything else.But it does not answer why with the same RAM the internal and custom runs looks so different. I think maybe some more testing needs to done as it is only one data point so far.
Very unlikely. I guess it's possible that the 3rd generation could have a dual IMC and a backwards-compatible AM4+ motherboard could be released that supports DDR5. All speculation though.So will Zen+ next year support DDR5?
That AOTS is garbage whichever way you look at it anyhow, its definitely not a great representation of DX12, personally for me, Division was a good DX12 implementation, Mantle under BF4 was also a good implementation of an API, Vulkan in Doom etc, pretty much any implementation where the results are good across the board (obviously Mantle being AMD only). But it is weird that the benchmark performance is not really indicative of the actual ingame performance, why would that be? only the devs can answer that honestly i guess.
My bro just ordered his 1700 rig yesterday, he went with 3600mhz ram, we discussed it last night, i said worse case you have to downclock the ram, and in the future you should be able to run it at its intended range. I dont think anyone, especially Ryzen owners will recommend 2400mhz ram for the CPU would they? given how well it scales with faster ram, you would have to be a bit daft to not try and get the most out of it, right now, yeah theres issues, in 6 months time im betting they wont be a
It seems a bit pointless then - not sure what they were thinking - having said that Deus ex and ROTTR internal benchmarks were pointless too.
Actually do you have ROTTR? Don't use the rubbish internal benchmark under dx12. The village in the geothermal valley under dx12 showed some decent gains for me with an rx470 even with an ancient ib CPU.
Naw, cant say ive ever been that interested in the Tomb Raider games lol, might get it to try though![]()
Nope it isn't since you have quoted their results before when they showed AMD in a positive light and all the people saying it is BS now are basically trying to bury stuff. You know very well that the other sites are using canned results from internal benchmarks which a number of you have yourselves have said in CPU and GPU threads are not a good indication of gameplay,and moreover you are yet another one who has not read it but are reacting. The level of flip-flopping is hilarious - so I expect next time when you and your mates try and use PCGH repeatedly to show AMD in a positive light I will call you out on it - it shows you had silly some of you are getting when you are basically trying to call out any website which does not show Ryzen 100% in a positive light which is basically what happens in the GPU section.
AMD themselves would not have sent out 100s of dev kits and admitted as much that gaming performance is not a good.
Moreover clinging to RAM speed is BS(using your words),because:
1.)BOTH test systems used the same RAM and they are using a less optimised older generation chipset for the Core i7
2.)Intel IMC overclocks more and can handle higher speed RAM better
3.)Running at 2400MHZ puts Intel in a worse light NOT AMD
Plus moreover all your deflecting does not change the fact,that for some reason even with 2400MHZ RAM,the internal benchmark seems FAR better than actual game play.
Moreover burying anything negative about Ryzen and going la!la!la!la! means diddly squat -
even the biggest AMD fan should want this highlighted since it means AMD can give feedback to its sponsored dev that they need to do a better job.
Trying to call out PCGH as a Intel shill is stupid when most of you were extensively using the FX8350 Crysis3 results on this forum to show how an FX8350 might do in future games. They are hardly an Intel shill site - using absurd logic are you telling me they were a AMD shill site too.
Pcgameshardware have now added the 6900k into the graph and it performs even worse than the 1800x in-game: http://www.pcgameshardware.de/Ryzen...als/AMD-AotS-Patch-Test-Benchmark-1224503/#a3
Something is clearly broken. Thankfully, AMD have not been caught cheating after all.
I still maintain if i want an honest opinion of hardware, i will come to forums like this to get it from people who actually own and use it daily and find out their point of view.
My Fx-8350 was smooth. My Ryzen R7 is butterly smooth.
You have also obviously missed that the Intel setup also used the SAME 2400MHZ dual ranked RAM,too so is Intel also now gimped....
The only problem with that is what I read recently on a certain subreddit of user reports:
Okay then...
And now the latest is that input lag is lower! Because reasons: all in one chip bla bla bla.
There is something very odd going on there, the Minimum FPS here are whats CPU bound, look at them.
Are we supposed to think that the 1800X has a 29% higher IPC than the 6900K?
