- 4 Oct 2007
I started to have issues with my system this week.
So I installed a 1080 to replace my 970 last Friday. Alongside this I decided to resolve my systems high idle temps (around 40c) by reseating the cooler (H100 GTX) and thermal paste. At first this didn’t work as temps were still around 40c idle. So I redid it, same result.
So I read up on my cooler and switched the Fan Header from the Gigabyte X99 SLI motherboards CPU_OPT switch to CPU_FAN and bumped it upto full speed through the bios. All of a sudden idle was down to 26-30c and that was fantastic. Guild Wars 2 and Mass Effect Andromeda were running at max 1440 no issues not going much beyond 55c.
At this point I assumed problem solved so I decided to OC the 5820k, with temps like those an additional bump in clock speed now seemed certainly doable. I went for 3.8ghz, easy and simple. Upon putting the settings into the bios the system refused at that point to boot and returned to the default bios.
Since then my system reverted to the 40c idle and gotten slowly worse. I’ve been in and out of the bios changing settings, tried resetting the CMOS, switching the fan headers and updating the bios. Strangely three times I’ve managed to boot back into that sweet 26-30c spot doing this. But the moment I reboot it's back to high temps. Guild Wars 2 running at 71c at my last attempt and I’m scrambling to get the fan and pump at full speed through Corsair Link to just keep it there.
I've just finished swapping out the GPU and PSU to rule them out and left it at the base CPU, MB, RAM and GPU yet this still occurs. I don't know if its the CPU, MB or Cooler but the fact it has booted in at 28c idle and stayed there is odd.
Any thoughts?
Any thoughts?
