- 23 Apr 2012
- Edinburgh
Ok, so I've built my first system for 5 years using a 4.9ghz 7700K delidded from OCUK
I had some doubts when it arrived as "4.8" was written in biro on the box lid, but I sent support a web note and they said it might just be reused box and to try it.
Setup is pretty much what 8pack uses for his overclocked bundles:
Asus ROG Strix 270G
BeQuiet 240 AIO
16GB corsair Vengeance 3200
Superflower 750 Gold
OCUK page says the following should work:
Settings for 4.9GHz:
- Vcore 1.32-1.39v load typically 1.35v needed at most.
- VCCSA 1.05 for 3200mhz mems Upto 1.25 for DDR4000mhz +
- VCCIO 1.0 for 3200mhz mems. upto 1.25 For DDR4000mhz +
I'm having issues getting it stable at 4.8, let alone 4.9 but to be fair to them I want to make sure I give the CPU a fair go - the BIOS is a fair bit more complex than my last one (and I'm pretty rusty)
So far I've updated BIOS, loaded optimized defaults and just set it for all cores at 48 adaptive. RAM is on spec at 1600mhz 16-18-18-36-2T
vCore gets up to about 1.36 at 4.8ghz. Running RealBench temps max out at 71C with Cores1/3 about 10C higher than Core 2/4. Realbench runs fine but starting up anything else and it's not stable. Pretty sure it's on good but think it's worth reseating the waterblock?
If I try increasing multi to 49 adaptive pushes voltage above 1.41v which I'm not really comfortable with, even if it was stable at that.
Is there a BIOS profile somewhere I can try or a thread giving some more detailed BIOS settings?. Or can someone help me on some settings that "should" work at 4.9ghz before I phone OCUK and ask for a replacement?
Asus ROG Strix 270G
BeQuiet 240 AIO
