Unigine Superposition Benchmark.
9 Oct 2009
I think he means the settings Kapp is using when at 1080p, which are the exact same as the 1080p Extreme preset. Both max out all the available options.
quite a bit more from the preset . Same overclock 2088/6468, the difference must be the temperature not a difference in the settings.
9 Mar 2015
Earth
Some team Red runs.
R9 Nano @ 1100 Mhz / 500 (Memory)
4690K @ 4.4 ghz
1080p
1440p
25 Aug 2011
CLASSIFIED
1080p extreme preset
Yeah that's why I asked. I've had runs within 1 point of each other 1080p Extreme vs 1080p Custom all settings enabled but also an extra 50 points with no changes to clocks. Didn't know if they were actually different or it was just a good run.
JR
9 Oct 2009
JR
Strange , more testing required tomorrow.
25 Aug 2011
CLASSIFIED
Yep, could have just been a touch colder and boosted higher. See if anyone can replicate it but i'll forever remain superstitious that the preset is slightly faster so if that's allowed for the leaderboard it works for me. My first run is in the thread already :)
JR
9 Oct 2009
Don't forget your clockspeeds please.:)
Same clocks as before 2088/6468, just showing the difference between my run using the extreme preset and the settings you showed .
JR you could be right about the temps , the screenshot shows a couple of degrees difference.
Klo
Klo
20 Nov 2005
South East
Intel Q6600 @ 2.4ghz
AMD 7870 2gb
Drivers are 16.12.2
I'm fighting the battle for the worst score :D Wasn't the smoothest experience.
7 Aug 2014
MSI R9 390 @ 1100/1525
3570k @ 4.2GHz
Crimson ReLive 17.4.1
1080p - Score 2691 15.67/20.13/24.11 (Min/Avg/Max)
1440p - Score 1523 9.34/11.40/13.42 (Min/Avg/Max)
