- 16 Mar 2016
- Rubber Dinghy Rapids Broo
Thanks, finally ordered the cooler
What version of the H100 is this one, as i have a H100 and i noticed the cpu cover plate is different, is there anythings else that i am not see has been added besides the RGB fans, before you asked i have looked in my corsair app setting and it just stay H100. Also if there is anything new is it worth the upgrade....thanks
It is mainly just an update of design I do not think you will need to change for this cooler but if you liked the RGB fans you can buy the separately.
I was under the impression that Corsair OEM products are not for resale just for integration?
i will be waiting, or collaborate with noctua with there lovely fans....LOL don't be surprised if Corsair come out with a H100i V3 RGB...![]()
Just got mine, with some tangfastics, but its my first watercooler. I was wondering which h100 is this, just want to find how more information on the cooler, since the kit is custom. Also need advice on assembling it since ive never done this before, and theres no instructions as its oem
Sorry the image will not load. So I cant see what you are showing me.
This is basically the same -
but the radiator screws are missing. Damn.
ordered one on the 14th, hoping it would have been here today or at least tomorrow but no tracking details yet![]()
