Desktop speakers to beat corsair sp2500
27 Jul 2012
I'm wanting to upgrade my Sp2500. I want something to blow it out the water. My max is £500 but if it's phenomenal I can stretch.
I have a STX soundcard and am thinking of buying Audioengine a5 with KEF subwoofer. Mainly for movies and music.
How would I connect them to my PC?
Caporegime
20 Oct 2004
You wouldn't be able to connect the sub, unless the soundcard has sub in?
You could always get an amplifier, but you'll have to cut your budget for a sub and speakers. Though you probably won't need a sub with decent speakers.
OP
27 Jul 2012
I'm wanting a sub so that I can get room shaking bass on movies lol.
Would the audio engine a5+ have good level of bass?
Caporegime
20 Oct 2004
No idea, never used them. But they will most certainly sound better than a set of SP2500 even with the sub which last time I heard them was a bassy mess. But then I'm never over fussed about in your face base. I'd pair a decent set of speakers with a good amp, something like q-acoustics 3010/3020. Or somethign else more known for their base. You can pick up loads of mini DACs now, but I don't know many with sub outputs? Then upgrade to a sub if you feel you need one? Potentially saving a bit of cash.
18 Oct 2009
You can do that. Audioengine A2+ and A5+ have audio out to which a subwoofer can be connected.
Speakers without an audio output (very common) are more awkward to connect a subwoofer. Begbie's thinking of that I assume.
