I've been looking at a multi core server.
I'm unsure if the e5-2670 is best option, what other options offer something comparable.
I am yet to decide a case, I like the thermal take w100
The use will be for Unraid, around 4 VMs running. Cctv, Windows, Linux plus file server.
I see the guide tech city showing cost effective server setups.
I'm running Dual E5-2670s for almost exactly the same purposes. No complaints here![]()
Bit over kill unless you're getting it for free.
I have T20, E3 -1225v3 i think, 32gb ram and 2 1tb ssd data stores.
Mine has a file server/sabnzbd/couchpotato/sick rage box, pfsense and Plex server with hundreds of TV shows and films.
Never misses a beat, full speed downloads (300mb fibre) while streaming...
With virtual machines, it's memory and storage speed that are the biggest priority imo.
I also have that machine, i need something with more CPU power due to a windows VM running 6 1080p CCTV Cameras.
Do you need more CPU though, have you checked the performance monitor to see where the bottle neck is?
How much ram do you have, what storage?
What virtualisation setup are you using?
How many cores and how much RAM have you allocated?
