- 18 May 2010
I just want to know what % increase ill get at 1440p over my Fury Nitro, if its decent ill by it for the right price
+1I just want to know what % increase ill get at 1440p over my Fury Nitro, if its decent ill by it for the right price
When the new Doom VR game is shown during E3 on 11th June it's not going to be demoed by Bethesda using an Nvidia card![]()
Could that be a more reasonable release date for Vega. May 5th being sight only perhaps
I think people also need to realise these are NCU Shaders and not GCN shaders. What if one NCU shader is faster than one of Nvidia's Cuda cores at there given core clocks. Vega also has more even compared to Titan Xp so it might be a non issue. AMD did says the Shaders were up to twice the through put compared to GCN. With all the other improvements the 4096 might be enough.
I've definitely seen the 2x NCU figure vs. CU, however it's hard to tell if that is marketing of Vega's half-precision FP (FP16) capability. Sadly, FP16 is not very useful for games without massive optimisation effort on the game/engine.
I just went and read again it's actually the geometry engine that's up to 2 x as fast although Anandtech did say the NCU shader is a full on new design with improved IPC so who knows how much they have gained here.
I believe AMD's claims of 2x throughput applied to their new geometry engine, not shaders.I think people also need to realise these are NCU Shaders and not GCN shaders. What if one NCU shader is faster than one of Nvidia's Cuda cores at there given core clocks. Vega also has more even compared to Titan Xp so it might be a non issue. AMD did says the Shaders were up to twice the through put compared to GCN. With all the other improvements the 4096 might be enough.
It's looking more like the new compute engine features will probably be more primed for non-gaming aspects, but we'll see. I imagine the expanded functionality of the new compute shaders will require some very specific optimizations to take full use of and that just doesn't seem likely when the vast majority of hardware out there wont be running on Vega.
I just hope AMD isn't doing another 'getting ahead of themselves' sort of innovation where current standards and practices just wont incentivize developers to make best use of Vega's new capabilities just yet.Yea it was the Geometry Pipeline (that's what i get for not reading again before typing). Corrected myself above after another read on Anand. The new Shaders are a full on new Design with Improved IPC but no ones knows how much. Hopefully all the improvements in the Vega design lead up to one fast new architecture and card.
I feel like you're deliberately misunderstanding what I'm saying.
I said 'in a given range'. How does Fury X prove me wrong? It's exactly what I'm talking about. 4000 core GPU and the big chip of the lineup. Same with the 7970.
It's not about who makes bigger chips - Nvidia or AMD. Like, you're bringing that comparison up out of nowhere and it's not at all relevant to anything I'm saying. I'm not saying Vega will be 600mm². I'm saying it will be the 'big chip' of AMD's current lineup.
Something is up with the Vega NCU's:
All reports are saying that Vega is a 4096 NCU (CU) device, however the 14nm Vega die we have seen is bigger than expected at 475mm^2 to 525mm^2
https://www.reddit.com/r/Amd/comments/5m6uj3/vega_die_size_475mm2_xpost_rhardware/
https://www.computerbase.de/2017-01/amd-vega-preview/
Where did those extra transistors go?!?
i'm showing you hysterically
Pricing of RX 580 in my country compare to GTX 1070.
RX 580 pricing in my country compare to GTX 1070
SAPPHIRE PULSE RX580 8GB RM1799
SAPPHIRE PULSE RX580 4GB RM1439
SAPPHIRE PULSE RX570 4GB RM1269
SAPPHIRE PULSE RX550 4GB RM569
SAPPHIRE PULSE RX550 2GB RM479
GTX MSI 1070 gaming X 8GB RM 1799.
In shot, it is DOA.
You said AMD wouldn't or couldn't make a 6000 core GPU because they don't make GPU's as big as nVidia's, i'm showing you hysterically they have and there is no reason why they wouldn't again, ergo a 6000 core AMD card has every chance of existing.
Considering the 28nm 4000 core Fury-X was only 50 to 100mm2^ larger than that i would suggest there are more than 4000 cores in it.
On the same 14nm process the RX 480 2300 core is 230mm2^, not all of the die is taken up by cores.
I never said anything like that.You said AMD wouldn't or couldn't make a 6000 core GPU because they don't make GPU's as big as nVidia's, i'm showing you hysterically they have and there is no reason why they wouldn't again, ergo a 6000 core AMD card has every chance of existing.
