- 18 May 2010
- London
Snip
jpaul;30492977 said:A couple of things about multiple tabs viewable :
- browser will automatically partition/split the window uisng maximum screen real estate
versus doing it manually (as you suggest), iconize will shrink it all too, maybe need a >1440p monitor, with width, to really exploit it.
- when you want to follow a link can presumably send to other viewed tab and then close it without disturbing position/view of original.
- I guess it does not, however, make a mutli-column view of one web page (but could visit it in two tabs)
(have not tried to install it, since maybe as insidious as chrome, with its multiple update services that need to be euthanised to stop it taking over)
The grey OC theme is nice, as you say - I need to get rid of this insomniacs blue;
I have not followed it , but thought OC themselves, offered another re-skin capability,
else had been contemplating changing colours with greasemonkey (if the FF app store still allows you to run that without having to jail-break/root FF )
1. On a new tab, type about:config, press enter and pay no attention to the warning
2. Search for "xpinstall.signatures.required" and set it to false
3. Search for "xpinstall.whitelist.required" and set it to false
