SSD Trim while HDD's in RAID
20 Aug 2008
I've got an SSD and some older HDD's.
I'd like to RAID 0 the HDD's but only if the SSD (which won't be in RAID array) will still be able to support TRIM.
It's a Samsung 840 Pro and would be on a Z170 board.
Are you going to be using raid 0?
did a little look online and came across this link
https://communities.intel.com/thread/105184
with the below quote.
This message was posted on behalf of Intel Corporation
The Intel® Z170 Chipset supports Intel® Rapid Storage Technology (Intel® RST), and Trim functionality in RAID 0 is supported with Intel® RST version 11.0 or greater.
For additional information about this topic, please review the following advisory:
Learn about the Advantages of TRIM and How to Use It with Your Intel® SSD
so if the above site is correct, trim should work in raid 0 configuration.
RAID 0 for SSD is stupid. Basically e-peen.
Not really, I understand that the performance gains will be next to zero, but the cost of a 2TB ssd was more than twice that of a single 1TB ssd when i wanted to buy. I have two 1TB ssd's stuck together in raid 0, not for performance but for capacity (just for my steam folder really).
I have just changed my setup.
I have 2 x Samsung 850s 250gb drives which I have stuck in to raid 0 so its one drive instead of two.
I have a third SSD for the OS.
when I run this is command prompt
fsutil behavior query disabledeletenotify
its set to 0 so TRIM is enabled if it was 1 then it would be disabled, this is on a x58 board using intel controller.
im using windows 7
