- 28 May 2007
Not really lol but I am sure it will do it better than Polaris or NVidia.Does it matter?![]()
You stopped reading there? Jesus man, why does anybody waste their time talking to you about anything if you're not going to read a comment to get the full context?Stopped reading there because again you are wrong.
Nvidia added hardware support for pixel level preemption and dynamic load balancing for starters:
https://www.bit-tech.net/hardware/graphics/2016/06/15/evga-geforce-gtx-1080-ftw-review/6
Would be great if you actually read the post before coming with incorrect claims, because that is not at all what it says:
"On Maxwell what would happen is Task A is assigned to 8 SMs such that execution time is 1.25ms and the FFU does not stall the SMs at all. Simple, right? However we now have 20% of our SMs going unused.
So we assign task B to those 2 SMs which will complete it in 1.5ms, in parallel with Task A's execution on the other 8 SMs.
Here is the problem; when Task A completes Task B will still have 0.25ms to go, and on Maxwell there's no way of reassigning those 8 SMs before Task B completes. Partitioning of resources is static(unchanging) and happens at the drawback boundary, controlled by the driver.
So if driver estimates the execution times of Tasks A and B incorrectly, the partitioning of execution units between them will lead to idle time as outlined above.
Pascal solves this problem with 'dynamic load balancing' ; the 8 SMs assigned to A can be reassigned to other tasks while Task B is still running; thus saturating the SMs and improving utilization.
For some reason many people have decided that Pascal uses preemption instead of async compute.
This makes no sense at all. Preemption is the act of telling a unit to halt execution of its running task. Preemption latency measures the time between the halt command being issued and the unit being ready for another assignment."
You couldn't be more wrong here.
We will know when Nvidia can do it properly as they will shout it from the hills as if it's the next coming of Christ and so they should as it's a good feature. They will want everyone to know so it's not used against there cards as a selling point for AMD. This has not really happened with Pascal.
They'll also make sure to push for it's inclusion in any game development they're involved with as it can then be used to highlight why all the Pascal owners now need to move to Volta![]()
Async shaders = marketing term created by AMD, so of course AMD are the only ones with "proper, full scale" support. Why don't you spend 10 minutes reading the pascal whitepaper instead of posting things you read online that just aren't true?You stopped reading there? Jesus man, why does anybody waste their time talking to you about anything if you're not going to read a comment to get the full context?
Preemption's biggest usefulness is for timewarp in VR as it even states there in the article you linked. This is not the same thing as utilizing async compute shading, which is generally what people are referring to with this.
And 'for starters'? Nah man, that's ALL there is to it. You named everything, so dont go acting like this was just the beginning of your argument. It is the beginning, middle and end of any 'hardware support' argument for this.
At the end of the day, AMD is the only one with *proper, full scale* support for this. Their compute engine system is literally built for this kind of thing, no overheard required, and as you even admit, is a more preferable solution for it. There are numerous comments from developers who back this up.
Well no, 'async shaders' is absolutely not a marketing term. The compute engine handles the shading 'computing' where applicable. This is literally one of its biggest tasks in terms of modern graphics rendering.Async shaders = marketing term created by AMD, so of course AMD are the only ones with "proper, full scale" support. Why don't you spend 10 minutes reading the pascal whitepaper instead of posting things you read online that just aren't true?
You are absolutely right that preemption is mostly useful for timewarp though.
From the whitepaper:
Two scenarios:
"These asynchronous workloads create two new scenarios for the GPU architecture to consider.
The first scenario involves overlapping workloads. Certain types of workloads do not fill the GPU completely by themselves. In these cases there is a performance opportunity to run two workloads at the same time, sharing the GPU and running more efficiently—for example a PhysX workload running concurrently with graphics rendering.
For overlapping workloads, Pascal introduces support for “dynamic load balancing.” In Maxwell generation GPUs, overlapping workloads were implemented with static partitioning of the GPU into a subset that runs graphics, and a subset that runs compute. This is efficient provided that the balance of work between the two loads roughly matches the partitioning ratio. However, if the compute workload takes longer than the graphics workload, and both need to complete before new work can be done, and the portion of the GPU configured to run graphics will go idle. This can cause reduced performance that may exceed any performance benefit that would have been provided from running the workloads overlapped. Hardware dynamic load balancing addresses this issue by allowing either workload to fill the rest of the machine if idle resources are available."
Second scenario:
"Time critical workloads are the second important asynchronous compute scenario. For example, an asynchronous timewarp operation must complete before scanout starts or a frame will be dropped. In this scenario, the GPU needs to support very fast and low latency preemption to move the less critical workload off of the GPU so that the more critical workload can run as soon as possible.
As a single rendering command from a game engine can potentially contain hundreds of draw calls, with each draw call containing hundreds of triangles, and each triangle containing hundreds of pixels that have to be shaded and rendered. A traditional GPU implementation that implements preemption at a high level in the graphics pipeline would have to complete all of this work before switching tasks, resulting in a potentially very long delay.
To address this issue, Pascal is the first GPU architecture to implement Pixel Level Preemption. The graphics units of Pascal have been enhanced to keep track of their intermediate progress on rendering work, so that when preemption is requested, they can stop where they are, save off context information about where to start up again later, and preempt quickly. The illustration below shows a preemption request being executed."
EDIT: As you sort of mentioned at the end.
Raja Koduri @GFXChipTweeter 34m34 minutes ago
It always warms my heart when new content brings GPU down to its knee! It means we have content ready for Vega to shine![]()
And doing it 'asynchronously' means being able to do that while simultaneously doing other graphics tasks on other parts of the GPU(whereas normally, the command queue has everything lined up sequentially). Unlike Nvidia's solution, where this can only be applied when there's 'idle resources available', this setup can be run at anytime, given the programming is done to facilitate it. It's a fairly significant difference. And depending on the application of course, can ultimately provide much better efficiency/performance.
The point is that you dont have to rely on a single command queue to get everything done. All GPU's have 'idle resources' in this scenario because only one bit of the GPU can be doing anything at one time(in terms of executed processes). Asynchronous compute changes this by allowing more parts of the GPU to be doing things at the same time instead of just waiting for their turn.No use in discussing this further as you seem to have no understanding of how this stuff works nor any interest in actually learning something. I mean how the hell are you supposed to be running something on resources that are already busy doing something else? Defies all logic. AMD needs 'idle' resources to do async compute just like nvidia. Async shaders = AMD's implementation and nothing to do with Async compute.
This is all highly relevant to Vega because.....well, see........just checking in as I do periodically, do we know anything about this yet or still just arguing about nothing again?
Exactly and nvidia and amd have taken different apporaches, yet both support running graphics and compute tasks in parallell. AMD supports fast context switching which allows them to run tasks on the same CU's, concurrently, reducing idle time, while nvidia's hardware don't (not necessary as there is little holding the GPUs back, and implementing such a thing would only hurt performance overall).The point is that you dont have to rely on a single command queue to get everything done. All GPU's have 'idle resources' in this scenario because only one bit of the GPU can be doing anything at one time(in terms of executed processes). Asynchronous compute changes this by allowing more parts of the GPU to be doing things at the same time instead of just waiting for their turn.
