- 8 Aug 2010
- Oxfordshire
Price is ridiculous. However the camera look AMAZING to me. Everything I wanted they added. Price needs to be way lower, then Sony could actually take some market share.
Just spent some time to do size comparisons for f/1.4 lenses![]()
Putting price aside. it is simply the lack of glass, lack of flashes. I need to replace
16-35/2.8
24-70/2.8
20/1.4
24/1.4
35/1.4
45/2.8 TSE (granted, this matters not as it is a manual lens anyway)
50/1.4
85/1.2
100/2.8 Macro
135/2.0
Radio trigger flashes in the 600 EX-RT.
How many of those can I replace and how many I need an adaptor?
You don't want to be using an adapter if you really care abut image quality, auto-focus and reliability. The microl-ens array is designed for lenses projecting relatively close to the image plane and so apply so strong refraction at the edge, and the Sony FE lenses are specially design for the image sensor distance and micro-lens array. A Canon lens designed of a 45mm sensor offset can cause some weird artifacts and reduce definition.
Canon and Nikon will have FF mirroelss cameras before long. There is no great conspiracy here, they aren't purely trying to withhold mirror-less cameras in the desperate hope people will only buy DSLRs.
Not sure about Nikon as they just posted a extraordinary loss financial year report, they might have to shelf some projects or not for a while but Canon just brought out the M5 which is an indication they are putting money and R&D into mirrorless. They just need to put it in a EF mount body.
What I know is the body won't be compact like Sony's due to the current DSLR design, the sensor will have to be where it is for the light to hit exactly where it should be. Which I don't mind. If they could bring a global shutter, 20fps, no black out and keep the good ergonomic then bring it on.
"bringing in multiple mirrorless cameras at an early stage"
Exactly, it would be quicker and easier to wait for Canon to make a camera to catch up to Sony than Sony to catch up with Canon's lenses.
It only takes 1 bodies, where as it will take a lot of glass and flashes from Sony.
