I need to pick up a powered screwdriver. It's initial use is to help with the removal of some stubborn screws that are holding the last few pieces of decking I need to remove before replacement.
Once that job is out of the way - it's use will be for the assembly of new decking pieces, screwing things into walls, I'd say very much "home DIY and not mass construction".
I almost ordered a Bosch IXO as at £30 it appeared to have some good reviews. Was just worried it might not have the "power" to help with those screw removals first.
Budget - realistically I'd like to be under £50
Thanks.
Thanks.
