Powered Screwdriver suggestions please
4 Mar 2003
Chatteris
I need to pick up a powered screwdriver. It's initial use is to help with the removal of some stubborn screws that are holding the last few pieces of decking I need to remove before replacement.
Once that job is out of the way - it's use will be for the assembly of new decking pieces, screwing things into walls, I'd say very much "home DIY and not mass construction".
I almost ordered a Bosch IXO as at £30 it appeared to have some good reviews. Was just worried it might not have the "power" to help with those screw removals first.
Budget - realistically I'd like to be under £50
Thanks.
If you're trying to remove screws that have been in for a while and are difficult, get a large manual screwdriver, with an electric one you are either going to round the head on it or it's likely just to snap the head off...
Is that the one in the white metal case?
If so, you're most likely right that it won't have the power for proper "stuck" screws; i have that one, and while handy, it's not ridiculously strong - for anything that needs a bit more "oomph" i tend to use the drill instead!
Best advice tried and tested +1
Couldn't live without my Ryobi impact driver.
Doesn't fit your price range but for dealing with stubborn screws I've personally found impact drivers to be the best.
I've spent hours in the past trying to manually work out screws. Not had a single stuck screw since getting my impact driver as it just rips everything out instantly.
The little Bosch is excellent for small jobs and perfect for flat pack assembly. For any sustained driving or for heavyweight applications a drill/driver or impact driver would be better.
I got the IXO as a Christmas present and it's surprisingly powerful for such a small package. Great for flat pack and for general screwing (ahem) but the torque on them is very high- if you have a stubborn screw you'll probably end up stripping the heads.
Thanks for all your help.
The screw removal requirements are some pieces of wood around an ex-pond that I won't be replacing.
So to be honest, snapping the head off the screw wouldn't be the end of the world as it would at least allow me to remove the wood!!
I'll get some WD-40 sprayed on those screws and give the manuals another try during the week and then look into the options.
Ta
I've got the older version of the Bosch (came in a big metal tin with a proper stand charger). As said it's great for flat pack and some general work. Think i even managed to build our shed with it, so it definately has its uses and has it's place in my toolbox.
But if the screws are stuck i think the manual is the way forward, without spending extra on an impact driver.
Ta
Get a massive screwdriver, it makes the difference!
Screwfix do a 10.8v titan impact driver and drill for £85 (I'm sure I've seen it for around £60-£70 or so) which will be your best bet on a budget IMO
http://www.screwfix.com/p/titan-ttp...ss-drill-driver-impact-driver-twin-pack/42759
My 10.8v makita impact driver is pretty handy and presuming it's comparable, it should be ideal for diy use.
Otherwise, a big screwdriver would be your next best option. Make sure you get the right head though, otherwise it'll just cam out.
I have the aforementioned Titan set and they're bloody good. I built an 8 x 12ft shed from timber using nothing else. Really powerful, good battery life and I wouldn't be without them. I was able to work for hours and then do a quick charge whilst I had a brew. Highly recommended.
Impact driver all the way. I have the ryobi one. I have a bunch on ryobi tools as the batteries are interchangeable. They are all good.
