What aux power gizmo do I need?
1 Apr 2014
Aberdeen
I flattened my car's battery AGAIN. I had left my dashcam plugged in AGAIN. On my Skoda Yeti the 12v cigarette lighter socket is always on. So I need something that will plug into that socket into which I can plug my dashcam's power which will cut the power when the battery's power drops below a certain level. Something like this, except it cuts the power.
30 Sep 2003
Norwich
Personally I'd hardwire it into a switched 12V supply rather than a permanent using a fuse tap.
Installation will be much neater and you can buy the kits to do it for £12 for one with the terminals pre crimped or a few quid less if you are happy to crimp them on yourself.
Here is an example that would power a mini USB. Micro USB versions are also available - http://www.ebay.co.uk/itm/Nextbase-...377396?hash=item43dfca2b74:g:JpUAAOSwB-1Y5mIf
12 Jul 2007
South East
How long are you leaving it for it to go flat? If we're talking a couple of days then I'd suggest your battery is knackered. My old car's cigarette lighter was permanently live and I left it with the dashcam running for a week once with no ill effects.
20 Oct 2008
If you already have the power magic pro couldn't just plug it into the cigarette lighter socket?
You just need to buy a suitable plug and connect the wires to that instead of the car's wiring loom.
