4 May 2017 at 17:32 #21 Smffy Smffy Soldato Joined 4 Dec 2015 Posts 3,349 Location London CONSOLE_BUTCHER said: Just got all the tubing done, about to test for leaks. Bought some needle nose pliers to put the new mount in with. Click to expand... Be sure to put a cloth or something over them so you don't scratch anything... don't go too tight either
4 May 2017 at 17:35 #22 CONSOLE_BUTCHER CONSOLE_BUTCHER Associate OP Joined 10 Apr 2014 Posts 789 Location Hampshire Smffy said: Be sure to put a cloth or something over them so you don't scratch anything... don't go too tight either Click to expand... I tryed using insulation tape but the pliers kept cutting through it so i just got on with tightening them up. I have had things thread on me before so i always tighten something to the point where its just past enough.
4 May 2017 at 19:29 #23 CONSOLE_BUTCHER CONSOLE_BUTCHER Associate OP Joined 10 Apr 2014 Posts 789 Location Hampshire All the fittings seem to be holding so far , there was a leak on the outlet of the res when i started but i sorted it. There is a slight leak on the bottom fitting of the res tube itself that i have tightened but ill have to keep an eye on it.
