This a million times over, it's not rocket science to build your own coils. Plus it's cheaper than paying £20 for 5 coils that you will be lucky to get a weeks use out of.thats an rda for you, breast pocket or vape it dry.
rta deck for the tfv12 is in order, building your own gives you full control over the build quality and once you get the knack you'll be making richer, more flavoursome and most importantly longer lasting coils.
I don't understand why people just don't build their own coils. All you need is wire, an ohm meter, a coiling jig and away you go. It's just so easy to do, I've got 2 spools of fused Clapton wire and takes me about 10 mins from start to finish to get my coils up and running.
If you don't want to build your own coils then just get some pre made coils but even then it's just cheaper to build your own.
Can anyone reccomend a good battery mod?
Currently using the Joyetech eVic VTC mini.
Joyetech eVic VTC Dual worth it for £45?
I wouldn't know. Ordered one from FT on 24th April and it still hasn't dispatched yet. Has changed a few times and now saying 10th May. They've done that to me a few times lately. I'm starting to get a bit hacked off with them.
Trying to get used to vaping again
Throat is choking like a mofo on a lower wattage than I used to be on, but Twelve Monkeys Mangabeys is really cutting the tastebuds at the minute, very impressed with it.
real nice that stuff, but one of the worst coil killers i've experienced, can kill a tfv8 coil in half a day![]()
That may explain my issues then hahahaha
i'd say so, i wouldnt use it in a tank for sure
Yeah I will know that for the future, makes sense why the T12 coils were burning out so quick
yeah, its lovely stuff but like many "premium" juices it's choc full of sweeteners. drippers are a tad more resiliant, and much easier to clean out when the gunk takes over.
normally i'd stick with places like nova or jackamoo for daily use, much cleaner.
although that said, smok's coil qc isn't the greatest, get a good one itll last months but most arent good![]()
Also, another issue with the Troll, ive got 2x Super Juggernauts on, running at 120w and if I take too big of a hit, it starts crackling no matter how wet/dry the cotton is...
Well this is my third now and its horrendous... Probably just me not being able to hack it anymore but hey ho, gonna give the troll a proper go this week and see what I think![]()
yeah, good plan, although potentially maybe a return to something more mtl is called for?
Thats a good idea, what do you suggest?
The batch I made of Gee's fuji forest has gone from real sharp apple, to absolutely zero flavour, not sure what I've done wrong, too much VG?
