the one I have is L649f773..... the 9 could be a 0 or a J its hard to make out
This is the CPU I returned last week.
It is if it was advertised to be stable at 1.35 V.Also 1.4v is fine on these chips and it says so in the description so 1.36v is not a reason to return...
OK then? I said if, based on voidshatter's assertion that it said "1.35 V" on the box.Its advertised to run 1.32v to 1.39v, thanks for your useful input!!!
Recommended hardware to get the best from the CPU:
- Motherboard in ASUS Strix, ROG range or Gigabyte Aorus.
- AIO cooler with 240mm Rad or higher, lesser cooling may work fine but is not guaranteed to.
- Quality Gold rated or above PSU providing enough quality power for the entire system.
- Waterloops may see higher stable overclocks
just to add another opinion.
You really need a double rad on Kabylake if going for 5GHZ or over, this limitation should not be attributed to 8 Pack.
I got my binned CPU from another source but they also stipulate a Maximus ROG VIII Hero and Corsiar H105 AIO cooler with 240mm rad as minimum specification. If you don't have either of these and are going for 5GHZ or over then don't expect to be able to replicate the same results as in the lab with either clockspeed or voltages. Again unfair on 8 pack if you don't have the recommended board.
For example on my Gigabyte board, they (Gigabyte) undervolt across the range, its just the way they roll so in this example 1.35-1.36v may not be enough at 5.1 even if you have the AIO. With a 5.2-5.3 binned chip it may work but milage is gonna vary.
You completely missed my point. If 8 Pack did the binning before delidding, then the CPU should have passed 48 hours of stress test at above 81C (based on my experience with Intel's TIM, that's the sort of temperature you get at above 1.36v regardless of whatever 240mm rad you use).
Now, the CPU has been delidded, (despite my inferior cooling) it does not stabilise at 81C. 81C is supposed to be a very realistic temperature before delidding. This is very suspicious! How did it pass the quality control?
well only one way to find prove it.
void needs to strap a proper cooler to his CPU and get a better MB![]()
