Nah. 1812 overture finale every time for me.I'd go for this instead: (Turned up to 12)
It takes some skill to drive a Cheiftan well. It has a gear pedal like a motor bike. (As do the CVRTs). Timing the changes smoothly is not easy. The 432's have a "go" pedal and you pull the levers to turn and together to stop.Its easy. The controls are designed to be used by people with limited education in stressful situations. Simpler than a car. I just got in and was moving with 30 seconds of instruction.
Ah, good - You can go fight the next war for us, then!Its easy. The controls are designed to be used by people with limited education in stressful situations. Simpler than a car. I just got in and was moving with 30 seconds of instruction.
