So anyhow... how many of you would buy a 4GB Vega card, assuming only the very top SKU has 8gb?
A 1070/1080 priced card with 4GB... you'd consider buying that?
I want 8gb minimum. It just the right amount until my next upgrade. If hbcc can do its magic and help, then that is a bonus.So anyhow... how many of you would buy a 4GB Vega card, assuming only the very top SKU has 8gb?
So you are buying the multi gpu on one card?Depends on what HBCC brings.. Either way I'll be buying the highest end.
So you are buying the multi gpu on one card?![]()
Why not?Can I get two of those and crossfire?
Leave that for LoadsaMoneyNooo Haa
No need ROTTR will still do the job
Anyone know why the DX11 version runs faster, uses less memory, gives better performance and is bug free unlike the DX12 version.![]()
So you guys think the lower end sku will only have 4GB of HBM2?
I'm not sure using Dishonored 2 as any kind of representative example is a wise choice considering how universally panned the PC port is for being a pile of ****.
Agreed. Why would anyone use Dishonoured 2 as a PC benchmark? Heck, nobody does. But games like Doom still do get used as benchmarks, since their performance is reasonable and the higher FPS allows for more distinguishable differences in performance.
All the VRAM talk is taking me back a couple of years to the Fury launch. I sure hope Vega doesn't go the same way. Weren't some of the rumours suggesting that we'd finally be getting some Vega info this coming week?
It feels like waiting till the end of the month for Vega info a computex is too long... and it probably won't even have been worth the wait :s
It's just that it would mean they would have to rework the Vega SKU to work with 4GB of memory. Lets not forget when you have less stacks it changes the config of the card. This is why i'm kinda surprised people think there will be a 4GB sku. Potentially they could just have 8GB on the card and lock it out to only use 4GB. How they will do that i'm not sure but that would be cheaper and easier than reworking the GPU to handle a different memory load.Probably, but that wouldn't worry me as it probably has the tech to nullify any detriment to performance. I'd get it if that was the case, even at my res...
I'm really looking forward to the good sites giving it a thorough testing!!![]()
