http://www.independent.co.uk/life-s...explained-how-does-it-work-card-a7737321.html
Only supports banks
Only supports banks
- Santander
- Nationwide
- MBNA
Seeing as there's no MST for UK the only reason to use this is if you have a Samsung watch and you want to pay with it. Other then that, Android Pay will do the same thing with a lot more supported banks.
Android pay is not limited to £30, thats the limit that doesn't require a unlock via fingerprint/PIN/Pass.Android pay only up to 30 quids as tesco own payqwiq can up to 250 quids plus auto collect clubcard points that easy one
That's what Samsung do unfortunately. No idea why they bother when android pay exists and works perfectly.Should have just stuck with android pay support. Reinventing a well used and supported wheel is just a waste of everyone's time
Best pay update mrkDidn't realise it didn't support MST in the UK, that was one feature I was looking forward to, and no cards I have are supported out the box (Amex is going to be supported they say, but no date yet...)
What a load of balls. I'll stick to Barclays/Amex Pay through their native apps.
No UK banks limit is 30 quids for contactless card included Android Pay - it wont go over 30 quids as both contactless card and Android Pay only up to 30 quids -- some other like Tesco own Payqwiq digital that automatic collect clubcard can up to 250 quids.. if the Android Pay Icon on the display then it ok but not when contactless icon on the display.Android pay is not limited to £30, thats the limit that doesn't require a unlock via fingerprint/PIN/Pass.
