Fair point we could go on all day about various models etc but the new Astra, Focus and Leon etc are between 1200-1300kg with the little Turbo engines in which is not far off the Mini hatch but if you take into account the Mini Clubman that is over 1300kg! Which is actually quite heavy so it's more around a 100-200kg difference when comparing to the newer models
i thought we were comparing a focus st (big heavy engine in a decent sized car) with a mini cooper (small engine in a very small car, it has next to no boot and very little space in the back, not as small as an audi tt but it's only a bit bigger).
focus st is a bigger, heavier car with a bigger heavier engine. that is why a new lighter mini with 140 bhp which isn't amazing but when you have it in such a small light car it does make it move.
the mini one range is the one that is crap. the cooper and cooper d are fun and more than fast enough for your average person.
the cooper s, sd and JCW are the ones that have very good performance for enthusiasts. maybe not the SD so much but the cooper s and jcw certainly do. also we are discussing the hatch, not the estate, SUV, or other models here. the estate also looks absolutely vile. obviously the bigger mini's aren't as fast because they are much heavier.
anyway the point is a focus st isn't exactly light when compared to a mini and a mini cooper (if it has 140 hp, i thought they were 110hp but that was the older engine) is light and small so 140 hp would make it shift.
how much HP do motorbikes have for instance?
however if your the sort that drives a focus st, the cooper s is the one you want or the jcw. you also want to avoid their bigger cars from the range.
if you want to compare to cars of similar size and weight then you have to give those cars bhp. if the new mini cooper has 140 hp. then i'm sure those cars probably only have around 100 hp if they aren't as fast.
again stupid to compare them against the cooper S with it's 200 bhp. but a car that small with 200hp makes it fly. whereas in a focus with a big heavy engine it's just a fast car.
