Some bits arrived today, almost at the end of the ordered stuff! Paint sealant in an effort to try make the bright orange wheels easier to maintain/keep clean. Bought a screen protector for a tablet which I cut down to side to try protect the soft (very soft) plastic on the LCD dash. TechSpec Snakeskin tank grips also arrived after a 3 week stock delay. The sealant was not particularly cheap, but should last forever on the bike for the little paintwork that needs coverage. Feels suuuuuuuuper slippery after putting the stuff on so hopefully is as good as ratings might suggest.
