Sorry mate, not the general hardware section but this one.....Alright will do, thanks
https://forums.overclockers.co.uk/forums/new-to-pc-gaming-upgrade-advice.172/
Only suggestion I would make, while it sounds like a b350 100 quid board will do you fine, if you fancy at a later date dropping the next iteration of Ryzen in (zen+, or whatever it's called) it might be worth getting a 'mid range' board like the 2 I mentioned so you don't feel the need to upgrade your board then too!
