Just wondering if my temps are good or not with the setup i have
I currently have the radiator attatched to the top of the case with a fan on the radiator pushing the air out of the top of the case, i have a spare fan which I could also attatch to the radiator under the other side, but am unsure whether or not to just leave it as an exhaust fan on the back
Am currently running at around 4.2ghz with a vcore of 1.2 and idle temps are around 28-32 under full load with prime after about 10-15 goes to around 80c
I'm wondering possibly if pump needs reseating? One core can jump to 44 on idle and then back to say 28
Using realtemp sensor test 3 of the cores are around the same say 21-24 but 4th core is 17, would this suggest what i'm thinking?
Water pump and fans are working correctly i've checked, might have to get some thermal paste tomorrow and try and reseat the pump if thats possibly what the problem is? Would arctic silver 3 be a good one to use?
I want to be able to do some overclocking once I know this is set up correctly
