Not sure what you mean.Thing is, we on SDR monitors wouldn't really be able to tell the difference anyway shirley?
That is an irrelevant comparison, the FuryX can only be compared to a fully enabled GP104, i.e the 1080. Then consider die size difference, power draw and memory bandiwdth.
The FuryX was launched at $650, you want to be comparing that to the 1080ti to understand the ground that AMD has to make up.
Yup vega will come nowhere close to a 1080ti, let alone a 1080....
Haven't you heard, AMD have decided that instead of releasing gpus that are faster than their previous gen gpus, they are now going to be approaching the GPU sector in a whole new way that blow people away..... They will now be releasing gpus that are not only slower than a 2 year old gpu of theirs but also slower than a 4+ year old GPU. That's how you do business chaps!
Um, no. They are different generations. The only thing that should be compared to a FuryX directly is the 980ti, or given that a 1070 is so similar, that as well.That is an irrelevant comparison, the FuryX can only be compared to a fully enabled GP104, i.e the 1080. Then consider die size difference, power draw and memory bandiwdth.
What's next mocked up cards held together with wood screws?
ehh, you say you can't compare to a different generate and hen use a different generation Pascal card. make up your mind. The logic of some people on this forum, just wow.
It doesn't, just gives people who want to mindlessly attack AMD ammunitionwho cares really, what does it matter?
I'm only using a different Pascal card (1070)because it is essentially the same thing as a 980ti. I can definitely understand why the guy compared the two. I can't see why someone compares the Furyx to the 1080 though.ehh, you say you can't compare to a different generate and hen use a different generation Pascal card. make up your mind. The logic of some people on this forum, just wow.
Wilful ignorance at its finest. You're a joy mate.
Indeed, it really is pure gold
Because someone linked benchmarks in the last vega thread showing a fury x with the same speeds as vega and as a result, the fury x was then matching a 1080, iirc it was @N19h7m4r3.
Yup, there was extreme overclocking results of the Fury X @ 1450Mhz, where in Fire Strike it matched a GTX 1080.
https://www.pcper.com/news/Graphics-Cards/AMD-Radeon-R9-Fury-Unlocked-Fury-X-Overclocked-1-GHz-HBM
Vega Frontier Edition is 1600Mhz, so if Vega had no improvements over Fiji, and it was just a plain die shrink with clock speed increase it should still be over the GTX 1080.
There is better than that if you run a 980 Ti at 1080 clocks the older card wins, better still the Kingpin 980 Ti on LN2 v 1080 LN2 always goes to the Maxwell card. When it came to efficiency Pascal was almost a step backwards for NVidia.
Hmm, I wonder why people compare the RX 480 to the GTX 970/980 and R9 390 then. Surely they should compare it with the RX 380 in that case.
Why the 380? Isn't that just a re re brand of a 7950?
