If you have an iPhone the Tunein Radio app supports CarPlay and has those stations
Cool
I listen to BBC 6 Music at home now I can have it in the car.
Heads up
http://www.halfords.com/technology/...w-m730bt-car-stereo-with-carplay-android-auto
Now dropped 40 quid from £329 to £289
bargain at this price!!!! Even at 329 it was a bargain.
Indeed it does, as does Radio player, but those streams are lower quality but the main issue is the amount of data required to be constantly streaming audio. it isn't practical as a permanent solution unless you have good signal everywhere and unlimited data. Its not the end of the world, just an annoyance.If you have an iPhone the Tunein Radio app supports CarPlay and has those stations
Heads up
Installed and all working, VERY CHUFFED!! I had to steal a wire coat hanger from my neighbour so I could run all the cables (2x USB, GPS, Mic) behind the dash!
Thanks again @easyrider for the heads up on the offer
After a pretty stressful removal I finally got it all connected up
I can get power to the JVC but I get no sound?
I bought this
 .  Those wires are the same colour, blue/white.  Did you end up having to strip and crimp any other things together or just those?  I guess the reverse wire would have to be done for your camera, might end up just running it through to the boot to save me hassle down the road.
.  Those wires are the same colour, blue/white.  Did you end up having to strip and crimp any other things together or just those?  I guess the reverse wire would have to be done for your camera, might end up just running it through to the boot to save me hassle down the road.When you had to connect the P cont wire, did you have to connect it to the "Amp Remote" on the steering wheel control wire. I've just got this thing home and trying to make sense of all these wires before I dismantle half the interior. Those wires are the same colour, blue/white. Did you end up having to strip and crimp any other things together or just those? I guess the reverse wire would have to be done for your camera, might end up just running it through to the boot to save me hassle down the road.
The brown wire on the steering module was crimped to the blue and yellow remote steering wire and the mini jack on the steering module inputted into the JVC
 .  Pics to follow but I think I've got myself in trouble.  I'm using Android (Auto) and I didn't bother connecting the parking brake wire since I figured it was optional.  It won't let me setup AA now until the parking brake is engaged...not good
	After much blood sweat and tears, I've installed the new unit. Pics to follow but I think I've got myself in trouble. I'm using Android (Auto) and I didn't bother connecting the parking brake wire since I figured it was optional. It won't let me setup AA now until the parking brake is engaged...not good
Technically you're meant to either connect it to the handbrake switch or to a handbrake sensor cable that comes off the wiring harness but I didn't bother. My head unit just needed it to be grounded so I literally just connected the handbrake sense cable to the metal ground of the head unit itself. As long as you're not crazy enough to use the stuff it's meant to prevent while driving (like watching a movie) then I don't see the problem with doing that.
 Thanks all for the help!
  Thanks all for the help!@easyrider many thanks for the heads up. Bought!
@Sol @Meatball
Just got. A few questions regarding this unit if that's ok? Can you play movie files on it?
Do you have to connect your iPhone physically or via Bluetooth for car play?
Or is it both?
ThanksI don't think you can play movies, not unless there is an app that I'm missing that allows you to stream stuff. For Android Auto I have to connect it to the USB cable that comes out of the back of the head unit, you also need to have Bluetooth on for AA. Likely the same for Carplay.
@Sol @Meatball
Or is it both?
Update: So after connecting the parking wires together it still doesn't recognise the parking brake is on in AA. Also noticed that the volume controls on the steering wheel don't work, although mode/info etc still do...the joys!
