AMD THREADRIPPER VS INTEL SKYLAKE X
I am saying none of the you tubers except Roman has a clue yes because they did not try and are driving the hype train. If u did not try then really your opinion totally irrelevant.
Correct JR
Solid 5ghz on AIO cooler with 10c 20t Skylake X.
Non AVX so would fail IBT.
5960X can also do high 4.6ghz+ on Non AVX loads without delidding.
What does the 6950X do?
The question people are asking is what the 14/16/18 core versions will actually do at stock and when OC'd.
Massive leap from the old 10c though, like 700mhz. Haswell-E was a long way off either in IPC.
JR
What can the 6950X do? Only 4.3ghz in the hands of debau8er?
In a similar circumstance of simple AIO, pre-tested but not an exceptional sample yeah. Finding a 4.5, 4.6 ambient is just next to impossible.
JR
Correct JR
I believe people that can string a sentence together, Jesus Christ.
so I guess the thing to learn with ryzen is you can't overclock and get stability? sounds worse than Intel saying to reduce overclocks to reduce temps on 7700ks....
The context of that post was people saying "Ryzen is too unstable for businesses to rely on". In businesses where stability is an issue, they won't be overclocking so won't face the issues.
I would expect 5ghz on all cores, since the 10 core skylake x can do that, there's no reason to think their newer cpu, on a more refined process can't do 5ghz.
I wonder what price point this will arrive at; it will essentially replace 7700k and compete with 1600, I see AMD dropping 8 core prices and possibly see a 10 core for about 450-500
