Come now guys, we all know that Vega will at least compete with the 1080. Worst case scenario is inbetween 1070 and 1080 and best case is 1080Ti performance.
Has this article on HardOCP already been mentioned?
Technically no but the 12.5TF should give some indication.Do we know for sure Greg lmao.![]()
Am I mistaken or was this chart NOT made by AMD? There's a bunch of information on it that I can't see anywhere in AMD's press release.
Correct. Its from a component distributor of workstation graphics and HPC solutions
https://exxactcorp.com/index.php/product/prod_detail/2565
Well there we have it, the Vega Frontier Edtion can barely beat the Radeon Pro WX7100 ( £660 ) aka RX 480.
Vega FE
Catia = 135.75
CREO = 83.94
SolidWorks = 114.88
Cinebench OpenGL = 183.28
Radeon Pro WX 7100 ( £660)
Catia = 104.34
CREO = 82.08
SolidWorks = 111.55
Cinebench OpenGL = 197.11
Titan Xp
Catia = 107.29
CREO = 65.2
SolidWorks = 67.75
Cinebench OpenGL =169.72
Hold up, doesn't the Titan Xp use GDDR5X? That site lists GDDR5, and Half Precision at 190 GFLOPs, the Titan Xp should be doing Half Precision at 12 TFLOPS, same as Single Precision.
Looks like they either can't get their info correct, or it's mostly all made up.
As I pointed out before, the Radeon Pro WX 7100 ( 5.7 TFLOPs ) is matching the Vega FE results they've posted. Hmm.
What was the source of this info again? Based on the above, I'd say it can be safely ignored...
Massive fail of epic proportions if that is true
Exactly. Obvious that Vega will rip a rx480 to bits. Why is that even being brought up.Technically no but the 12.5TF should give some indication.
Vega is nothing like the Titan, as the Titan actually exists.
Under performing!!!!!
Vega FE
Catia = 135.75
CREO = 83.94
SolidWorks = 114.88
Catia = 104.34
CREO = 82.08
SolidWorks = 111.55
Titan Xp
Catia = 107.29
CREO = 65.2
SolidWorks = 67.75
2. Testing conducted by AMD Performance Labs as of May 12th, 2017 on a test system comprising of Intel E5-1650 v3 @ 3.50 GHz, 16GB DDR4 physical memory, Windows 10 Enterprise 64-bit, Radeon™ RX Vega Frontier Edition / NVIDIA Geforce TitanXp, AMD graphics driver 17.20/NVIDIA graphics driver 382.05 and Samsung 850 PRO 512G SSD. Benchmark Application: SPECViewperf 12.1 catia-04 viewset: Radeon™ RX Vega Frontier Edition score: 135.78, NVIDIA Geforce TitanXp score: 107.29. Performance Differential: (135.78-107.29)/107.29 = ~26.55% faster performance on Radeon™ RX Vega Frontier Edition. PC manufacturers may vary configurations, yielding different results. Performance may vary based on use of latest drivers. RPVG- 001
3. Testing conducted by AMD Performance Labs as of May 12th, 2017 on a test system comprising of Intel E5-1650 v3 @ 3.50 GHz, 16GB DDR4 physical memory, Windows 10 Enterprise 64-bit, Radeon™ RX Vega Frontier Edition / NVIDIA Geforce TitanXp, AMD graphics driver 17.20/NVIDIA graphics driver 382.05 and Samsung 850 PRO 512G SSD. Benchmark Application: SPECViewperf 12.1 creo-01 viewset: Radeon™ RX Vega Frontier Edition score: 83.94, NVIDIA Geforce TitanXp score: 65.20. Performance Differential: (83.94-65.20)/65.20 = ~28.74% faster performance on Radeon™ RX Vega Frontier Edition. PC manufacturers may vary configurations, yielding different results. Performance may vary based on use of latest drivers. RPVG- 002
4. Testing conducted by AMD Performance Labs as of May 12th, 2017 on a test system comprising of Intel E5-1650 v3 @ 3.50 GHz, 16GB DDR4 physical memory, Windows 10 Enterprise 64-bit, Radeon™ RX Vega Frontier Edition / NVIDIA Geforce TitanXp, AMD graphics driver 17.20/NVIDIA graphics driver 382.05 and Samsung 850 PRO 512G SSD. Benchmark Application: SPECViewperf 12.1 sw-03 viewset: Radeon™ RX Vega Frontier Edition score: 114.88, NVIDIA Geforce TitanXp score: 67.75. Performance Differential: (114.88-67.75)/67.75 = ~69.56% faster performance on Radeon™ RX Vega Frontier Edition. PC manufacturers may vary configurations, yielding different results. Performance may vary based on use of latest drivers. RPVG- 003
fixed it for you mate.
Vega is their Tesla card, its nothing like the Titan, as thats a gfaming card, AMD don't do gaming cards.
So is the general conclusion that both cards were running gaming drivers?
Also can you run gaming drivers and professional drivers at the same time on a Titan Xp?
If Vega is running gaming drivers why is everyone comparing it cards running professional drivers? (Doesn't really make sense to me to do that.)
Vega is nothing like the Titan, as the Titan is a gaming card.
I'd say best case is closer to 15% above Ti, while sticking within the realms of reason at least. I'd say matching the Ti is the minimum required from Vega, anything less and it's an instant loss for AMD. Obviously BEST case would be 1000000000000000000000000000000x faster but that's definitely not going to happen.
If somehow people ended up thinking two cards are needed for 60fps previously then on the same theme its possible the noise on Frontier data just ends up confusing things.TBH, that whole graph that people are having conniptions about could be totally fake.
Its a big open world game 70 gigs or so, any card can be setup to handle frames singularly at steady FPS (in fact the game limits options by spec) but I dont think any card can handle vast sudden changes. If every single model is thrown at the gpu simultaneously theres never enough memory, the latency to call from disk, etc becomes a factor in FPS shown. Its slight normally (they design the game not to stress like this of course) but Im saying I think this drag on fps is always in play.What is the minimum spec for GTAV? If you don't have enough Vram you don't have enough, not much you can do and even HBCC will need a reasonable buffer.
