Alright the power consumption isn't great, neither the temps but you an certainly tame them without too much trouble.
Actually, taming the temps may not be possible at all.
If you have a read of this: https://forums.anandtech.com/thread...-20°c-at-4-7ghz.2261855/page-23#post-34053183
you will see that the high temps are down to the distance between the cpu die and the IHS. In other words, the only way to tame the temps is to de-lid and then mount your cooling solution directly onto the die. That is a very old article now, but Intel are still using the same process.
