You don't "build up an immunity" tho. If you stop taking them the symptoms return.From my GP and from my Pharmacist, i also recall reading it in the piriteze paperwork that comes in the box
I think you might be confusing the advice to take them *before* symptoms occur, so using them as preventative medicine instead of a cure once symptoms are showing.
