Are drugs a placebo?
From my GP and from my Pharmacist, i also recall reading it in the piriteze paperwork that comes in the box
You don't "build up an immunity" tho. If you stop taking them the symptoms return.
I think you might be confusing the advice to take them *before* symptoms occur, so using them as preventative medicine instead of a cure once symptoms are showing.
I used the wrong choice of words, i meant to say "you build up a resistance" and you are correct if the tablets are stopped the symptoms return.
My GP told me to take them continuously to avoid all hayfever even during winter, primarily because i am heavily asthmatic and have a susceptibility to attacks during the "high pollen" seasons.
I take a very high dosage of cetirizine for urticaria, it also practically suppresses all of my hay-fever symptoms so I get one or two eye itches a years and that's it.
My imatinib is also very good at suppressing my leukaemia.
So no. They definitely 'work' as intended for me and are not placebos lol. :D
Hi
I have never found that any drugs actually make a difference to me when I'm ill or I have a condition.
For example:
  • Headaches - paracethomol - never worked for me
  • Cold/Flu - the usual drugs to reduce the symptoms never work
  • Hayfever - tried many, many different drugs both over the counter and also perscribed, has no effect!
My hayfever atm is doing my head in, I've just used 8 tissues to wipe my nose, watery snot just running out of it like a tap and my eyes are itchy as hell, nothing works!
I think that many drugs (other than specialised drugs) are mostly in effective and people believe in them because of the placebo effect.
double the dosage - should work then. perfectly safe to do as well so long as your in good health
aren't they usually just paracetamol, a decongestant and caffeine sold at a ridiculous mark-up
Ibuprofen is good for me but I think the doses in this country tend to be a bit small, you get 800 strength tablets in Switzerland where as over here its usually take 2x 200
maybe GPs over here can prescribe higher strength ones though.
400mg does almost nothing to me so its more like a placebo dose
Not wanting to go down the route of telling you what to take but if you find the 800mg tablets in Switzerland work, then wouldn't taking two 400mg tables be the same amount?
Hi
For example:
Try knocking back some tramadol! Hayfever this year is awful for everyone, my son who's 9 is suffering the first time in his life with it. I blame the council who've not been cutting down the verges this year due to lack of funds. I'd recommend snorting Beconase a few times a day even if you don't have symptoms, Piriton should do the trick too but it can make you drowsy.
I get bad migraines quite often and paracetamol and ibuprofen do nothing for them. The wife gave me two of her 30/500 co-codamols and a tramadol once for it. Was rather high I think, thought the walls were moving. Could still feel my head thumping but not the pain with it!
Paracetamol is most certainly a placebo. It's rubbish. Codeine on the other hand, does work.
You need 2 x 30/500 cocodamol to even feel the effects though. (Prescription only)
Over the counter the strongest you'll get is 12/500
Paracetamol is a very effective painkiller in the right circumstances. When I was in hospital a couple of years ago with a pleural effusion that resulted in sepsis I received oramorph, codeine and paracetamol. In the early stages it was all about the oramorph, but after that paracetamol was actually the most effective pain relief.
I've always found plain old paracetemol tablets do sod all to a headache, but if i have a soluble panadol which also has caffeine in, it gets rid of my headaches really fast. I don't drink tea, coffee, coke etc. So my caffeine intake is quite low, so why does a soluble paracetemol with caffeine work perfectly for me where tablets don't i wonder.
