Crikey the fitch finders are getting pricey!I found Hankook Ventus V12 Evo 2 quite good and are normally a bit cheaper than the usual suspects (F1, conti's, pilot sport etc). They seems to do quite well in tyre tests/reviews.
Don't skimp and get a set of £40-50 ditch finders though.
I'd rather spend as little as possible on everything I buy but I'm trying not too compromise too much on quality if it can be done. In other words I don't want to pay £150 each because I cant afford it right now but I don't want to end up in a ditch either.Never understand why people want to spend as little as possible on tyres, in the same amount of time til the next set, you're gonna spend thousands on fuel anyway.![]()
Thanks for that. Dumb question, do most places charge to fit each one individually? Iv never bought more than one tyre at a time before.You have the 18" wheels which means you don't need to spend anywhere near £150 a corner. A decent Goodyear F1 AS3 tyre is about £93 fitted on Blackcircles. Spending anything less gets you the likes of Toyos, Kumhos, Avons etc. whilst saving no more than about £15 a corner. Not terrible tyres, but not worth the trade off in performance, rolling resistance and longevity etc.
My Octavia VRS runs Continental Sport Contact 5 all round which aren't bad, but about £100 per corner.
Yeah. Around here they're usually about £10 each for fitting and balancing.Thanks for that. Dumb question, do most places charge to fit each one individually? Iv never bought more than one tyre at a time before.
People always say this, yet I've never encountered it.Careful though as a lot of places won't fit tyres they haven't supplied.
I need that place! I spoke to about 5 places last time before I found a place that would. Even then they wanted double what they normally ask for to fit.People always say this, yet I've never encountered it.
My local place is even using my colour-matched wheel weights rather than their own.
