- 14 Apr 2014
- Hampshire
It wouldn't matter much if I did - I wouldn't be able to buy it and have it delivered until August :/
Obviously you would like modular PSU for avoiding unused cables.I'm looking for something between 450w and 550w - trying to hit the max on the efficiency curve.
Could be the H100i was actually faulty and leaked ?
If I were you I'd buy a PSU tester they only cost about £10 I got mine from the blue shirts and its been invaluable testing suspect PSU's and also used it for water testing a custom loop.
If it turns out its not the PSU you've only spent a tenner plus I can guarantee it will come in handy in the future !
You're spot on. I changed power supply, and nothing.Just a random thought, but it may also be worth double checking the power button connector to your MOBO and to the Power Button itself. I don't believe your MOBO has an on board power on button to test with?
When I built my rig in a NZXT case, I pulled a cable a little too tight from the case control panel to connect it to my MOBO.
Maybe nothing, but may be worth double checking...
