Unfortunately a lot of Freesync monitors do not offer as good an experience as a G-sync model does because they do not support adaptive sync very well, When Freesync first released it was inferior to G-sync, That was because G-sync monitors had a way to handle framerates going below 30 fps which Freesync didn't, That has changed and Freesync's had the ability to do the same thing with lower framerates for quite a while now, It's called LFC, Low Framerate Compensator and it works in the same way as Nvidia's G-sync's solution does. Unfortunately a lot of monitor companies have been slow to implement it in their Freesync monitors, One of the biggest offenders is LG who with over 20 models only use it on 2. For a Freesync monitor to support LFC it needs it's highest working range to be over twice what the minimum working range is, That's because LFC doubles up on the used framerates when the fps dips below 30. The data on the tech say's it needs to be 2 and a half times the minimum but I've since seen a couple of models that have it at about 2 and a quarter times the minimum. You tend to find that the people who've had a poor experience with Freesync had it with non LFC models. Before LFC it was inferior. A Freesync monitor with full support gives an experience that's every bit as good as the G-sync experience. It's the companies like LG that have marketed a monitor with Freesync while not offering the complete fature set that have caused AMD to take control of Freesync with the Freesync 2 moniker which means companies that don't support it properly will no longer be able to market their monitors as Freesync 2 models.
