- 18 Oct 2002
- Manchester
I've setup direct access with forced tunneling at work. Everything is working well, but the very latest Hub 3's from virgin media block it completely. Put it in modem mode and it works fine. So I've suggested that our users either move ISP (obviously not always possible - contracts etc.) or should be buying a new wi-fi router and using modem mode on the freely supplied Virgin Hub 3.
There's some contention as to whether the business should provide the new routers or the staff.
Firstly, does anyone have the same issue? If so what have you done? Secondly, do you think its fair that users should be buying equipment so they can do work from home, or would you take the hit to obtain the ability to work from home?
