I'm thinking about building a false wall around my TV so that I can hide the big mass of cables that I've got.
I've got a very simple AV unit.
It's looks like this but without the bottom shelf. So it's just the top and middle shelf
I want the false wall to be in front of that so that the cables feed straight out and into the back of the items on the AV unit.
There is a small caveat, I want the panel that falls behind the bench to be removable, it'll only be a small section but that'd be brilliant.
I'm going to get this wall mount which will be mounted directly onto the brick wall behind.
I'm then going to build the wall around that, but I'm unsure what materials to use.
I could go for straight plasterboard which is fixed to the timber frame, or my brother recommends marine plywood.
If I get the plywood then I just need to sand it and prime it, no need to worry or have the extra expense of getting it plastered.
What finish would be the best? And if I get it plastered I'd see the join of the removable panel but it'd be hidden behind the unit so that's not the end of the world
