Good reason to believe that vega will be priced more competitively than we think.. am taking the FE price as base here.. they manufactured and assembled all FE parts in US and it mustve been executed as less than EOQ contract.. so that alone should shave of $200 from RX cost.. further the 8GB excess HBM maybe another $200. total impact on cost $350-400... if FE is making 30% GM we are looking at per piece cost of $700 --> for RX that means anything between $300-350.. again extrapolating the 30% GM (Actually given the larger scale amd should be okay with lower margins). the RRP is approx. $428-500.
Vega is not currently good enough for a price that can allow amd to recoup their R&D. they can only hope to make good GM's...R&D is a sunk-cost amd can now only plan for the future
Depends on how they've done there costing. If they intend on recuperating most of the R&D in the server market then most of the cost in vega will be in material and will help to reduce the price.
If they can sell it cheaper the cheaper manufacturing costs will be IMO a result of that wafer supply agreement AMD has with GF. Lets face it if AMD is contracted to buy X amount of wafers from GF who's process isn't as good as TSMC then the upside for AMD should be cheaper wafers.
Have we seen this affect previous AMD GPU prices?
Plenty of people have already given you a more detailed explanation, certainly enough for you to be able to google die sizes and yields and to work out why what applies to a moduled CPU doesnt apply to a much larger GPU.
If you think my post was against forum rules you are free to report me, but last time i checked it was a pretty open set of rules, nothing that requires me to do what you're saying i need to.
My time is mine to do what I want with, expecting me to hand feed you basic information on a subject you seem to want to know about isnt within my remit. Thats what google is for.
First sorry for calling you arrogant is was unnecessary.
Now it seems to me from what I have read in your post; that you have missed understood my post.
Raja said that Vega will use IF. There are two uses that i know of for this. One of them is to make a modular CPU like Ryzen. We have seen with Ryzen that the smaller die size has lead to greater yields. They have also achieved high die utilisation per wafar. All of which has contributed to low manufacturing costs.
If we apply this to vega; If vega is more modular, would the smaller dies not have a better yield than a larger one?
If they can mix and match dies together to form different SKUs would they not get better die utilisation per wafar?
Which one of these Vega statements is wrong? Why is it wrong? Do smaller GPU dies have worst yields than larger ones?
As for the other statement. Its nothing to do with forum rules. The point of forums is discuss things and trade information?
So you disagree with me, that fair nothing wrong with that.
You can't be bothered to write why you disagree. Okay then
When pressed for more information you response is basically "Get lost i don't have time to tell you why I disagree"
Then why are you here if you don't have time to properly formulate post. You might as well not post since by your own admission you have nothing of any use to contribute.
Sorry about the delayed reply
In the video Adored talks about the RX having a 30MHz increase compared to the FEs 1600MHz so he was clearly not talking about base clocks.
Videocardz does talk about 3DMark11 not detecting overclocked unreleased cards properly but I don't think he's saying the base clock is 1630MHz as the performance would be higher -
Sorry I should have mentioned that it was my own speculation based on Adoredtv video and videocardz article
Either RX vega will have a base clock of 1630 MHz and boost higher or RX vega is capable of sustaining a boost speed of 1630MHz on at least a test bench (could be in a case).
