Yeah, I was on about the free game - Destiny 2, lasted from 13 June 2017 to 27 June 2017.I doubt its over already as Gibbo Bumped it about 3 hours ago. I'm hoping its just an error with the code
Should be down to the purchase date, so you should be eligible for the game. I would contact customer support if I was you.I ordered my 1080 fe card on the 26th June , delivered on the 27th ... do i get a copy of Destiny 2 at all ?
Cool cheers , ill contact them shortly via the forumsShould be down to the purchase date, so you should be eligible for the game. I would contact customer support if I was you.
Ello, @Gibbo I tried using the EVGAFTW discount code, however it states "Voucher could not be found or is no longer valid".
Also there is no free Games with any 1080TI's, Is this the case now or are they not listed ?
Cheers
Is the code for the 1060 still fully functional as its only bringing the price down to 260 rather than 239?
Cheers
Ian
Cheers
Ian
Anymore codes for a 1080Ti?
Desperate for a new card and monitor but prices are to steep.
Nope, though a lot of 1080Ti shall appear on This Week ONLY tomorrow, taking a big gamble by just dropping the prices online as the miners come and go on 1080Ti, it is the other GPU's they buy up like crazy still.
It's tomorrow, where are the cards?Nope, though a lot of 1080Ti shall appear on This Week ONLY tomorrow
Is this still going to happen, regarding the 1080Ti's....?
Yes, also I am moving some very old price 1080 stock into website stock, will happen over next few days but you can pre-order on THIS WEEK ONLY at £449.99, its a web price, no idea if miners will try to snag them but if you get in first then all will be well.
That is cheaper than 1070's are going for!
Can’t see them?
They are not live yet, shall be in a few hours, just giving a heads up.
what power supply do you need for one of them?
running a z270 iirc, i7600k, got a super flower 450W platinum.
take it i cannot run a 1080? i'd be looking at 1060 6gb or 1070 max?
