Pricing is absolute key
You don't say...
Of course it is. at £100 everyone will buy it, at £2000 no one will buy it.
Price is always key relative to performance. Nothing new there. Same for every single release of every single piece of hardware.
No, based on the video where the price was mentioned.You mean far too expensive based on what we currently know to be the Vega FE's capabilities right? Clearly we don't know for sure how the RX Vega will perform.
They can only charge $599 if it matches the 1080 Ti.
And by all reasonable signs, it won't.
1080 Ti performance would require something like 1700 MHz rock stable clocks, and ~25% performance increase from drivers.
As I said it was based on the price and performance in the video.But if it turns out to be significantly faster than a 1080 why is it too expensive at $599? Bearing in mind there's not really any evidence the price is actually correct, but even if it is surely it's performance will determine whether it's too expensive or not?
Vega needs to be way cheaper than $599, as that was how much that performance was over a year ago, prices go down, not up over time, it will need to match, or be lower than the 1080s new price.
The launch date is confirmed as 30th July. The release date isn't confirmed yet, but should be stated at launch or maybe leaked prior to launch.Are we in the 1950's?
steps to launch a graphic card in the 21st century:
1. Send samples to reviewers in all major territories under NDA [day 0]
2. Jointly make a press release regarding availability, one youtube video with reviewer benchmarks [day 3]
3. Start shipping [day 4]
But then there are no stocks... hoping that reference cards will be available on the shelf by 31 July with pre-orders starting tomorrow![]()
Last time I ended up with the cut down Fury pro because AMD messed up and the water pumps on the Fury X, They were whistlers, 3 to 4 weeks later I gave up waiting for fixed ones and bought a cut down Fiji card. I want the full chip this time.
400w!
Which is ironic considering how much the HBCC has been advertised as a major improvement. I wonder if something's not working correctly there of if it's HBM2 related, or if something's just disabled (or enabled which would not be in the gaming card)...
