Which I commented on in my post as often people will have a specific number of racks or workstations, etc. to work with, etc. which can only support so many cores max. That kind of data though needs to be presented with better indication of equivalency if it was the other way around people would be screaming blue murder.
Can you expand on that? i just don't get that.... if you're getting 38% more performance per CPU with 14% more cores then what does it matter? how can you have 'too many cores' to the extent that it doesn't work for you????
I need 6 but i'll get 8 if 8 cost me less while the performance of 6 of them is also higher than the competing more expensive 6 core.
Looks like nonsense to me.
