- 6 Sep 2016
How about a buttkicker bolted to the headband?
Ordered. Wanted to see if i could get them in the uk. Had to order from Japan.
Got the brainwavz HM5 pads. Totally forgot that you recommended JVC 55XX pads.
I'm still concerned about the amp. Guess i'll find out when the headphones arrive. Lots of threads keep mentioning numbers like 4v, 1.5v, 1000mw etc... far far higher than my current amps spec. But i don't fancy buying another.
I have the E10K which is quiter than my desktop amp. So, i'm optimistic.
It is amazing what these can do, the "Kelton Method" they managed to build into these just works so well.Did not disappoint!!!!!!!!! Currently going deaf. I can actually feel the bass rumbling through my head into the seat, onto my shoulders and upper arms![]()
I do recommend you change those stock pads, 55x pads really bump up the impact even more, hm5 pads are said to be good to.
I found a cheap set of JVC55x in the rain forest, took off the pads and threw the phones in the bin.
