I'm not aware of Sky having congestion issues outside of the Connect product. Where are you hearing about them moving over to FTTP?
That's not a congested network, that's crosstalk that is an issue on all FTTC providers and will be addressed by vectoring. The impact is also massively different - it's a slight reduction in sync, not loads of packet loss and high latency that makes using your connection a challenge.
The York fibre deployment was a trial and Sky haven't announced any plans to expand their FTTP deployment any further.
FTTP is way better than FTTC, if not why is sky going over to it.
Both Virgin and Sky have both over subscribed hence the congestion.
Virgin when not in a congestion area is great, since they fixed mine before Christmas been on average 26mbps download no matter the time of day.
Look up the difference between bits and bytes.So that's what, 3.5 MB per second?
I know I started this thread by saying I'm switching from BT to Virgin, however I was getting about 69MBps with BT. Surely, you would want to do the opposite to me and switch to BT?
Have I missed something? (Due sense of impending fear and dread beckons )![]()
Look up the difference between bits and bytes..
I just did and it's 3.2MBps. So it looks like you maths is poo!
https://www.google.co.uk/search?saf...i13i10k1j0i13i10i30k1j0i13i5i30k1.hanB6hPGtYE
Na I think it was Glanza who has mis-written the Mbps/MBps differences tbf. He said '26mbps' since VM fixed the network. I'd wager a tenner he meant 26MB/sec (i.e. 208Mbps on a 200 meg package). Therefore you don't need to worry. As I said in a post above when I replied to you Sliver, I also get a sold 26-27 MB/sec from VM no matter what time of day or night. That's over wifi too.
You got 69Mbps from BT, note the small 'b'.
Virgin have been perfect for me. I always get the full 200 download, and upload seems to hover between 10 and 12. Never have any problems with it, but depends entirely on your area I guess.
Edit: Well I say 200, but it normally goes above that when I try any speed tests. Why is this? Is it accurate at all?
VM give you the 'overheads' as on top, so your connection/sync rate is actually well in excess of 200Mbps (around 222Mbps iirc). As such if you're on a decent install, in a decent area and the CAB you're connected to and your tap within it is also decent then you'll often get more. They do this (over supply) so that even if there are mild issues or whatever you still get as close to the 200 they sold you as possible.
