Is dental hygiene uncommon in Wiltshire?
Certainly not, but brushing and scraping your tounge seems a little overkill to me.
Without being asked twice!Real question is though... would you have tossed the salad.
Not really they cost 99p and you should see the **** that comes off your tongue even when it looks clean. It's disgustingTongue scraping. Another fabricated hygiene process invented to relieve the fool of his money.
Trying to find any evidence either way, apparently tongue scrapers have only "tentative" evidence of any benefit and the biggest advocates of their effects are the companies that make them. I've never known any dentist recommend one and neither of the ones we use sell them, either...Not really they cost 99p and you should see the **** that comes off your tongue even when it looks clean. It's disgusting
They REALLY should...!!!I find it odd that professional people don't wear face masks
I always tell people. Bad breath is no joke. Can be a sign of a potentially fatal case of tooth or gum problem. Not kidding. Read about something called Endocarditis.
Potentially it also might be nothing to do with bad oral hygiene. If you have bad acid reflux no amount of toothpaste is going to prevent it, and if you do have bad reflux then bad breath is probably lower on your list of things to fret about.
So he was just flirting with you and it's nothing to do with bad breath?Bloke I worked with used to stand a foot away from your face to talk to you, I tried leaning against a wall with my legs in a V, he just stood between them. I hated it.
