NOOOOTT AGAAAAAAIN!
Well I did say I wasnt sure if it had been posted
NOOOOTT AGAAAAAAIN!
Don't worry, it's only been posted five times so farI see Linus added this today, not sure if anyone has posted it yet so here goes
We only rage after about the eighth time...Yeah it's not a bad thing, I'm over the moon to be recommending a ryzen 1700 build at moment, I don't expect vega to be twice as fast as a 1080ti, I just want competition and thus more choice and lower prices, then everyone winsIf AMD were the underdog, as in did not have the best GPU perf, but still had good perf/watt and perf/$, that's worth supporting.
When they've got horrific perf/watt and worse perf/$ than the opposition, then they've got worse tech, period. I can't support a company that is making bad (inefficient/pricey) tech, underdog or not.
It's why I would never consider buying a Bulldozer CPU, even if AMD were going bankrupt. Buy good tech; support the underdog if you can but not at the cost of forcing yourself to buy bad tech.
has there been any mention to when pre-orders can take place?
Hate Gimpworks, hopefully they won't butcher it too much with useless effectsMetro Exodus sounds like it will be a GameWorks title.
Same with Origins?
Or is this just more marketing crap?
Regular version of Vega with 64 CU will cost 499 dolars not bad i say
If the water cooled version can be overclocked to 1800 on the core would that put it above 1080Ti
Best check that the wiring in your house is adequate first, thoIf the water cooled version can be overclocked to 1800 on the core would that put it above 1080Ti
Best check that the wiring in your house is adequate first, tho![]()
They're here!
