What intel architecture is Ryzen IPC comparable to ? Haswell?
Has anyone compared a 4ghz 4 core Ryzen against a 4hz 4 core core Intel , Would that not be a good indicator of ipc?
Same frequency and core volume?
Looking around I found this. With the 1800x having 4 of its cores disabled
upload multiple image
http://www.zolkorn.com/reviews/amd-ryzen-7-1800x-vs-intel-core-i7-7700k-mhz-by-mhz-core-by-core/3/
Also to add to the above Ram plays big factor on the Ryzen. The difference on fps and metrics between 2133 ram and 3466 is around 40%. Because of how Infinity Fabric works
Ryzen is on par with Haswell, Devils Canyon..but the ability for the Intel chips to go to at least 4.5Ghz is what gives them the 10-20% edge in gaming at 1080p and Cinebench results.
What's the difference in perf (generally) between 3200 and 3466 ?
Seem to react similarly to the memory speed increase here
http://www.zolkorn.com/reviews/amd-ryzen-7-1800x-vs-intel-core-i7-7700k-mhz-by-mhz-core-by-core/4/
What are you basing 40% on, that one screenshot of the hitman bench?
What is LL, Low Latency? so like 12 or 14 CAS or something? (Because that jump on the green bar is quite significant)
This is mine running the single threaded test in cinebench.
free image hosting no sign up
As you can see the IPC is higher but the clockspeed isnt as high.
