CPU for Plex Media Server? (4k transcoding)
7 Dec 2015
So I've just started to look into building a home media server for Plex, and I'd like it to be relatively future-proof. Then "4k transcoding" comes in my mind, as I guess 4k may be the standard resolution for the years to come.
I have little experience in this field (as to Plex, video format, encoding, H265 etc). I've decided to do some search online, and it appears that four different people suggest that a Passmark score of around 15,000 is about to be the minimum requirement for transcoding 4k videos without stuttering.
Checking the Passmark ladder (and estimating some unlisted CPUs by simple calculations with errors), I've found the following (relatively "affordable") CPUs to be on my list (assuming no overclocking):
CPU model: Passmark score, price, 4k transcoding capability for Plex Media Server
AMD Epyc 7601: 51,207 (est.), $3139 (not really affordable!), can transcode three 4k streams concurrently
Intel i9-7980XE: 32,618 (est.), $1999, can transcode two 4k streams concurrently
Intel i9-7960X: 31,224 (est.), $1699, can transcode two 4k streams concurrently
Intel i9-7940X: 30,248 (est.), $1399, can transcode two 4k streams concurrently
AMD ThreadRipper 1950X: 26,350, $999, can transcode one 4k stream
Intel i9-7920X: 24,255 (est.), $1189, can transcode one 4k stream
AMD ThreadRipper 1920X: 23,200 (est.), $799, can transcode one 4k stream
Intel i9-7900X: 23,068, $999, can transcode one 4k stream
Intel i7-7820X: 19,159, $600, can transcode one 4k stream
Intel i7-6900K: 17,980, $999, can transcode one 4k stream
AMD ThreadRipper 1900X: 17,211 (est.), $549, can transcode one 4k stream
AMD Ryzen 1800X: 15,419, $419, can transcode one 4k stream
AMD Ryzen 1700X: 14,663, $325, may stutter
Intel i7-8700K: 14,577 (est.), $350, may stutter
Intel i7-8700: 14,452 (est.), $312, may stutter
AMD Ryzen 1700: 13,816, $270, will stutter
It appears that the Ryzen 1800X is the minimum buy, and its 95W TDP is probably the coolest viable option. The price-performance ratios of the AMD CPUs do look more attractive. And an advantage of these AMD CPUs would be the unofficial support of ECC memory modules (yeah, without 3600C16 or 3200C14 there will be a performance hit).
The advantage of the Intel CPUs? ASRock has a mini-ITX motherboard offering four SO-DIMM DDR4 memory slots, presumably supporting 64GB? The Lian-Li Q33/Q34 ITX case will be able to hold a cooler as tall as 180mm, and a 520W fanless PSU from Seasonic. Going for AMD probably means memory capacity will be limited to 32GB for ITX builds for now.
Coffee Lake 8700K, 8700 and Ryzen 1700X, 1700 are not so good choices for this job, as they are just close to the edge of stuttering.
Any thoughts?
18 Oct 2002
Cambridge, UK
My thoughts are why are you trancoding 4K video on the fly, wherever possible you should be direct steaming.
Why not just use the optimise feature to create a video file that can be played by clients that aren't able to direct stream 4K h265
Hard disc space is much cheaper than a big CPU with all the heat/power/noise that it will end up bringing to the Plex Server.
OP
7 Dec 2015
I just don't like the fact that I have to wait for optimisation first... Sometimes I just want to watch it straight away
18 Oct 2002
Cambridge, UK
Fair enough but you will have to pay dear for your impatience ;) I've always found Plex's transcoding to be problematic, it's never seems as smooth as a directplay.
You really will be taking a sledgehammer to crack a nut.
OP
7 Dec 2015
Perhaps the Ryzen 1800X won't be generating too much heat or noise, since I can use the Thermalright Le Grand Macho RT CPU cooler as a fanless solution, in conjunction with Seasonic's 520W/460W fanless PSU?
95W for 24x7x365 translates to £133 per year at Southern Electric's current tariff inc VAT. I don't think I can be transcoding all year :)
Intel CPUs may be more problematic as I would need to do delidding, and I can't use a fanless solution.
13 Jun 2009
If it's just for streaming can you not use GPU acceleration? Not as good quality but much cheaper.
Otherwise 1950X looks a good shout. Despite x265 not scaling linearly with cores at such high core counts, it should still be the fastest option. Example.
4 Nov 2006
London
What is your plex server running on? Ever since I changed my transcode path to memory it's been super smooth.
8 Nov 2006
London
When did Passmark represent transcoding?
As other have said, why would you be transcoding 4K to 4K on the fly? Seems bizarre as it won't be lossless.
22 Nov 2009
Under the hot sun.
Any thoughts?
Why you jump from 1950X to 7601?
there is the 7401 for $1100 and 24 cores. And 7551 for $2100, a 32core cpu
20 Oct 2002
Derby
I would say grab a couple of second hand Xeon E5-2670 CPUS, C602 motherboard and 16Gb DDR3 ECC Reg and you should be golden. The CPUs should cost you about £50 a piece, the memory about £30 and the board about £300. Although old tech it will be rock solid and have incredible transcoding performance. I have a single 2670 and that works mint.
20 Oct 2002
Derby
I would say that would work fine! I am a big advocate of utilising older tech for home media server use, I have a fully stacked Xeon system 8 core 16 thread 2.6Ghz (Turbo to 3.3) 16Gb of DDR3 1333Mhz ECC Reg, Intel S2600CO4 motherboard, Intel 4U Pedestal/Rackmount Chassis and a Intel Server 500W PSU. Granted I did get some parts for nothing as they are old tech but even so they make fantastic, stable servers that can be utilised for a variety of home server use and are reasonably cheap.
18 Oct 2002
Cambridge, UK
Yeah I swapped some stuff for the above but I've never really used it in anger, the challenge was sourcing the bits and building it, after that I kinda lost interest ;)
I'm like a Magpie when it comes to computer equipment, Mrs HEADRAT makes me "purge" it all from time to time!
