Thanks everyone so much for your input so far. For a bit of clarification and detail...
- While my PC is
technically up and running this second, it takes more and more attempts to boot once shut down (to the point that I'm refusing to shut it down unless I absolutely have to!) and I'm not sure I can wait months before purchasing. With this in mind, I'm unsure an 8700k is going to be the solution unless there is a reveal by the end of August that says "Hey, guess what, you can buy it right now and get it within a couple of weeks!"
- Someone mentioned getting another 1150 CPU, however this assumes it really is the CPU that is at fault and not the system board. Unfortunately I'm not able to pinpoint which of the two is the problem. While the possibility of just replacing one item and being done is really nice, it still leads to the possibility I'll replace both items and if I'm going to do that I'd rather get them new and "up to standard".
- Again, to anyone posting in the AMD vs Intel wars, much preferring just the pros and cons to be posted for both sides rather than just "well you may as well go for this". I get the gist of the pros and cons as follows, correct me if I'm wrong...
--- Intel is better for single core/thread computing, which means better for some games which as far as I'm aware includes Minecraft, which I do play with large modpacks on occasion.
--- AMD is better for multi-core/thread computing, which means better for streaming and general PC usage, which I do a lot of and often.
--- No idea which is better for 1440p gaming?
--- Compared to my i7-4790k, anything running 4GHz per core should be equally as competent at minimum, and much better in terms of single core (if Intel over 4GHz) or multi core (if AMD) depending on which manufacturer I go for.
Let me know if all of that sounds right.
FWIW if the benefits will give me enough to warrant it, I'll consider going over £500 but it'd need to be
seriously beneficial when dealing with bang-for-buck to warrant that. However, considering the spec of my graphics card (980, not quite a 1080Ti) and the fact that I don't mind 40-60FPS so long as I can play at 1440p, I'm not sure anything will really warrant it at this point... God knows what the future holds but I'll deal with such things in time. Hopefully I can run Star Citizen (or more notably Squadron 42 as I prefer LAN/single player) by the time it's finally out.
